Hi All,
I just made all the necessary backups before applying the latest FP2 update.
When applying the update, my phone stops in recovery mode, and the log screen reads:
Finding update package…
Opening update package…
Verifying update package…
Installing update…
Verifying current system…
Verifying radio-update…
System partition has unexpected contents
E:Error in /cache/fp_update_.zip
(Status 7)
Installation aborted
I then rebooted from the recovery tool, and tried again: same thing.
When I boot my phone, it’s still using 1.8.1. One thing puzzles me when I check the manual install support page https://fairphone.zendesk.com/hc/en-us/articles/207914363 : it states that the install file is about 600Mb, and the download time when using the updater is a couple of minutes: it does not match the necessary duration for downloading such a file on my internet connection.
Any idea ? I believe I could try manual install.
