Given:
- FP3 (Android 10 ; build: 8901.3.A.0084.20210204)
- Lawnchair 2.0-2589
- 2 SIM (both secured with PIN)
- Unlock schema required after screenlock (like short pushing the side button below the sound control)
- No faceId or digitalId activated
When:
- Reseting the OS (long push on the side button + reset or sporadic reboot bug)
And:
- Lock the screen (quick push on the side button or wait for the autolock, like in the pocket)
Then:
Expected:
The phone can be unlocked after typing SIM 1 PIN / SIM 2 PIN / Phone Schema -
Found:
The phone remains in a unlock PIN loop (of Sim Card 1). If the code is wrong I got the proper notification but with a correct PIN I remain on the SIM 1 unlock screen
==> Important is the Lockscreen action, as if it implies that in the background the Unlock-Flow is frozen because it can not go further
