I get this every time i try to access the Calendar. I am using 5.1 on my fairphone 2
i need to know what is causing the error so that i can avoid it because i cannot afford either the data or time loss in re-setting to factory settings every time this happens
Is “Unfortunately, Calender has stopped” an error message you receive?
What happens if you try to open your calendar app?
How many times did this happen?
What happens after restarting the phone?
Is data missing?
What kind of calendar do you use? I guess the default google calendar?!
Did you install the last updates? Do you know the OS version of your phone 1.2.8,… 1.3.6 (open “updater app” for these information)?
I hope these are not too many questions, but I think that they could help to analyse your problem.
(So please just try to answer them, if not do not worry, we will try to find a solution)
…Yes that is the message verbatim
…When I try to open the app, I get the above error message
…Every time until I give up (after circa 5 times in a row)
…I get the same message
Is data missing?
…Not when I look at the calendar via my pc
…in fact, i still get the reminders of meetings coming up in 30 minutes etc, i just cannot open the calendar via my phone to add more meetings
…it is indeed the default google calendar!
…Yes
…1.4.2
Since posting this problem, I have re-set to factory settings 4 times. I have now noticed that the calendar works to start with but stops working when another app attempts to use it
it is strange that the calendar stops when an other app tries to access it. Do you mean if you export a date e.g. sharing function on a website to you calendar?
