Unable to connect to Wi-Fi
I have user with Fairphone android version 15 cannot connect to our school Wi-Fi. Wi-Fi encryption is WPA 3 only and you need to install the certificate to connect the network. We use all criteria I saw online to connect the Wi-Fi but still failing with Authentication problem.
Are you also unable to connect to other wifi networks or only to this specific one?
In addition to the prior question:
Which Fairphone is it (there are a few possibilities), and is Android 15 the one from Fairphone or an alternative Android OS (there are a few possibilities)?
Is this EduROAM by any chance? Best is to use the official app for that.
For example:
I can connect to a guest Wi-fi with splash page. I can not connect to the work wi-fi that required the certificate. EAP method is PEAP and Phase authentication is MSCHAPV2. Select Use System certificate and entrer the domain too
It is not EduROAM. It is a school Wi-Fi with WAP3 only Encryption.
It is a Fairphone 4.
