Unable to connect to bootloader through fastboot
Hello, my name is Pepe. Sorry for bad english.
My operating system is windows 10 pro
I am unable to connect to fastboot mode.
Things I did:
Activated developer options
Enabled oem unlock
granted permanent permission
adb devices show device OK
reboot in fastboot mode (bootloader)
fastboot devices shows nothing
Things I tried:
several computers, several cables, several drivers
Nothing worked
Any idea?
Thank you very much
Normally you need to connect the phone to the PC while in fastboot, go to windows updates, search manually, select optional and install everything bootloader related
Ok.
Key was…. install driver manually and choosing Android from the list. Then forcing the installation.
Thank you very much. I now have e/os installed in my FP4 and it’s amazing, I love it !!!
Just in case other users find this topic with the same issue, here’s an animation from a Fairphone support page showing the install process via Windows Update - Optional updates …
https://support.fairphone.com/hc/article_attachments/18494377825809
