Since this is an A/B device, there is no separate recovery partition.
Recovery is part of the boot.img.
I have linked to a full stock dump above. (Which could be used with fastboot to get back to stock state)
You can also backup your boot.img using TWRP.
That’s what the installer is for, it would replace the recovery in the boot.img.
I don’t think anyone has tested that yet.
Well you need to enter a PIN/password for the work profile when you setup one. I’ve used the same as for the screen unlock for convenience reasons. TWRP does not seem to be able to decrypt with the correct PIN/password though.
Ah yeah, I forgot about that.
You can also set it to the (full) path of prebuilts/misc/linux-x86/dtc/dtc which is included in the omni-build tree.
I guess I should just include an updated version of dtc in the kernel.
@k4y0z I noticed there are a number of binaries and binary libs inside the TWRP repo. While the kernel modules can probably be taken from the compiled kernel source and the bagiskboot tool could be compiled as a submodule, I wonder where the stuff in vendor/lib64/ comes from and if that is by any chance open source - or are those proprietary qualcomm libs?
Sorry, had to wait one and a half hours before replying, since I’m a new user…
The steps are fairly simple:
Install the Magisk-ZIP from TWRP
Profit
Oops, I’ll change that for the next release.
I used the moto g7 tree as base for the fp3 tree.
There are no kernel modules in the repo.
The libs and binaries are mostly proprietary and are needed for encryption.
They are from the stock images.
Some of them could be built from source, but in the case of TWRP, that would just complicate things.
For building a full custom ROM that’s a different story.
I tried the installer and now it only boots into the recovery, im guessing it broke the OS?
Edit: Yep, phone doesnt like boot slot A, essentially boot loops until it defaults back to slot B. TWRP and fastboot are the only things I can access, there also still isnt a stock ROM available, any ideas?
Mhh, that’s strange.
You had Magisk installed before installing twrp, correct?
Did you do any modifications on system or vendor, or just mount either of these RW?
Did you reinstall Magisk after installing TWRP?
I had magisk before installing, I think I mounted system and data with write but didn’t modify anything, phone doesn’t seem to want to boot TWRP either now, including through ADB, switching it on sends you straight into fastboot.
I didnt reinstall magisk afterwards because it refused to boot anyways, I would recommend people who try the TWRP installed dont install magisk first. I think i’m going to have to wait until there is a custom ROM available.
Use the stock dump I provided and flash boot.img using fastboot.
Then reinstall TWRP and Magisk. (in that order)
It didn’t boot, BECAUSE you didn’t install Magisk,
Since you triggered verity by mounting system RW you need to reinstall Magisk, which will disable verity.
I see, I tried to flash the boot.img but im getting this error:
sudo fastboot flash boot boot.img
Sending ‘boot’ (65536 KB) OKAY [ 2.416s]
Writing ‘boot’ FAILED (remote: ‘partition table doesn’t exist’)
I think my partition table is corrupt? Anyway to restore/recreate a partition table?
IT WORKED!
I flashed the boot images to both slots and had to format /data, But it booted nonetheless, thank you so much, I dont think I would’ve figured that out by myself. I was almost certain that the phones partition table had been corrupted.
