Transparent cover
I would buy the fairphone 2 with the transparent cover, but in Italy they only sell it with the colored ones. Do you know where I can find cute transparent covers?
Fairphone discontinued the transparent covers (all “regular covers” were discontinued because they tended to disintegrate easily – the rubber and hard plastic would not stick together in the long run and the hard plastic would easily crack near the corners) :frowning: You can only try to find a used one, e.g. in the forum’s unofficial market place.
