Hi! My phone is a second edition FP1. I recently noticed that apps that display their frame rate usually show frame rates of above 60 fps. For example, the classic GL Gears demo shows a steady frame rate of 63 fps and the cocos2d test app settles at around 62 fps. As I’m pretty sure the display will not refresh more than 60 times per second, these extra 2-3 frames are not only wasted, but since they are never displayed, they add choppiness to the animation.
I have not been able to test this on another Fairphone, but I have tested it on a lot of other phones, and they all show frame rates of 60 or less, so a logical next step would be to figure out if this is an issue with all Fairphones or if it’s something local to my phone. So, anyone with a Fairphone, feel free to give the Gears app a try, it’s available here and requires no special permissions: https://play.google.com/store/apps/details?id=com.jeffboody.GearsES2eclair
Thanks for the tip. I’m not having any luck getting the data though. I’ve turned on Profile GPU rendering in the developer options, but the output from adb is quite disappointing:
johannes@broxomatic:~$ adb shell dumpsys gfxinfo com.jeffboody.GearsES2eclair
Applications Graphics Acceleration Info:
Uptime: 538024 Realtime: 538024
** Graphics info for pid 6374 [com.jeffboody.GearsES2eclair] **
Profile data in ms:
com.jeffboody.GearsES2eclair/com.jeffboody.GearsES2eclair.GearsES2eclair/android.view.ViewRootImpl@41393980
View hierarchy:
5 views, 0.00 kB of display lists
I’ve also tried enabling OpenGL traces, with systrace as well as logcat but the output is always the same. What am I getting wrong here?
