Timer Stock Camera FP5
Hi! Is there any reason why the delay timer is only available in “Portrait” and “Pro” modes?
While the Pro mode can typically be used in many situations, there seems to be no solution to get the timer work using the wide angle camera.
Thanks by advance!
It’s also available in other modes.
You have to pull down the settings to find the timer.
You’ll find an according screenshot in this (German) post:
Dear Volker,
Thank you very much for your reply.
Have a nice day!
