Last night the device rebooted again
I’m starting to experience the same thing since today. Very frustrating. I’ve had a very good experience with this phone for a year.
You have e/OS installed as mentioned in your other topic while the OP has FPOS installed
This could be a sign.
The problem might not depend by the OS?
I’m having the FPOS installed.
So your post in the eos topic is misplaced. Will move it here.
Same thing here from today!
Provider: Telekom (Germany)
Single ESIM
Tbh I don’t think this is an OS-dependent problem. In the bug report I can see WPSS crashed, and the driver failed to load. This is a more serious problem.
Do we have a sub for shared issues between eos and FPOS?
No and the forum here is no way to report it to Fairphone, so please report to support with the details you have. At the moment it does not seem to be a widespread issue
Edit: does it only happen when connected to wifi and is it a wifi connection?
Thanks! Sure, I’m aware this is not an official way to report the problem and I’ve reported this to Fairphone.
It also happens when Wi-Fi and/or Bluetooth are disabled. As I can see, shortly after the system can’t load WiFi/Bluetooth Driver correctly, it will freeze and restart.
Updates from my side: even after installing the latest release, several factory resets include erasing ESIM profile, the problem continues to exist, and the logs show exactly the same symptom (that the driver can’t load itself correctly). I’ve sent it to the repair center.
Does anyone else experience the same symptom?
For what I know, the support center is investigating. I dont’ think that sending the device to the repair center will solve the problem.
I keep on waiting. (last reboot thre night ago!)
Thanks! Actually me neither, but since the problem is not widespread, I hoped I could get a new device so I can sell it to someone else. I already bought a new device from other manufacturer.
I’ve never had this problem, but if that were the case, I’d probably reflash the stock ROM and replace the battery.
Replace the battery? In a new device? Should I pay for this?
If it’s a power source issue, the problem would likely recur under heavy load. Is that the case ?
No, it’s not a power source problem. It happens in an absolutely random condition
I believe they should replace the device as part of the warranty process. That would be reasonable. Good luck!
I am having a similar issue in Germany, single physical (German) sim, FP6.QREL.16.100.0
Since a month ago, I think. At first, I thought it was a specific charging cable I used at work, so I changed it. But then it rebooted again this morning, while unplugged and low on battery. So that’s not it.
It always seems to happen while the device is idle.
update from my side: the repair center of Fairphone changed the main board of my Fairphone 6, and now it’s working again. Though I’ve already sold it to someone else.
