In my new FP4 on the top left of the screen I see a long provider name (“Vodafone NL - voda NL”)
The result is the time is not visible and i can’t see the notifications of Whatsapp and other apps. This is due to the selfie camera in the middle.
No option to “undisplay” network name in settings/display/advanced. So the problem still exists. Nevertheless I am very happy with the phone … … Android version 11 according to the phone info indeed.
I ordered my FP4 during the presentation on sept 30th using the webshop on fairphone.com. I was refreshing the webshop and approx halfway the presentation the FP4 appeared in the webshop.
Just received it yesterday so maybe you guys will receive it also soon. In fact one of you may be smarter then me and find a solution. Let me know then!
Don’t forget specific settings can be found through Settings’ search function, usually with a magnifying glass icon near the top. I’d also search for terms like “hide”, “network”, “network name”, “carrier”, “operator” etc.
@JuneGill : problem still persist @urs_lesse : thanks for the tip but searching did not deliver an option to hide network name
Strange thing is I took a screenshot to show you whats happening. But the screenshot shows the part “behind” the selfie cam wich is not visible on the screen … … I´ll try a second phone to make an oldfashion screenshot to show you whats happening.
So this on the locked as well as unlocked Display? Not sure that can be changed for the locked Display (here you can see the clock quite big in the middle of the screen)…for the unlocked screen in the settings you can search for status and there might be an option ( per default enabled on the FP 2 with LOs 18.1/Android 11) called something like " turn off/disable symbols in the status bar". If this is not ticked, can you tick?
Edit: also under status bar you can change the clock position.
@yvmuell Its both, in lockscreen and normal screen. Your tip : The status search in settings led to “Stille meldingen bovenaan verbergen…” but it did not change anything @anon93683458 I see the provider name hopping around some pixels up, down, left or right when i try the options. No option available that makes the time and notifications visible sadly
Not nitpicking at all. Notifications are important, whereas we usually know the carrier’s name except when roaming, and you can find it in Settings anyway. It’s hardly what I’d call essential info.
