Has anyone managed to install three in touch on their FP2? In the app store it says unavailable on your carrier - anyone else had this problem? Thanks.
I just got it to work. If you have two SIMS in then disable the non 3 SIMS.
Download and run the Three in Touch app using 3g or 4g with WiFi disabled.
It should then connect with Three in Touch. You can then enable WiFi and the second SIMS.
Don’t bother phoning 3 about this issue, they haven’t got a clue.
Rob
