The Dark-Light toggle has moved
The Dark-Light toggle has moved from the top menubar to the hamburger menu.
Besides manually toggling the Dark-Light mode you can now also enable Auto Detect mode so that the forum Dark-Light mode changes automatically when your device’s Dark-Light mode changes.
Old location
main-menu
New location
How did you do this? Do you use this plugin? That one only seems to allow to add the toggle to the site header.
It’s a bit counterintuitive that one has to select a color scheme for dark mode first before the switch becomes available.
Wouldn’t it make more sense to preset one of the dark mode themes and just have auto-detect set to off, so it’s always there.
Or is that already the default and it’s only missing for me because I changed those settings at some point? :thinking:
Yes, that’s the one. I unchecked this option in the theme component’s settings:
Users whose account existed before the new theme was installed a few weeks ago indeed need to manually set a Dark Mode theme before being able to use the toggle. Unfortunately there is no way to have it set automatically for existing accounts.
Ah okay, then it’s because I use the new sidebar, there is no support for that, yet :slight_smile:
