Texting app does not work in landscape mode
Is it just meor is the texting app worthless in landscape mode? This is what I see, I can’t see anything of what I’m writing. In vertical it works, but my touch screen is dead where the letter A is in vertical…
If your touch screen does not work correctly, you should visit the troubleshooter on Fairphone’s support page.
You should select the following options: “Display” → “The touch function is defective”.
I’m using an alternative SMS app, Signal, and there I can see the input field in landscape mode with keyboard.
Unless you are using Fairphone Open, The default texting app is Messages by Google. You should report this issue to them, since they maintain and update this app.
