I can’t send text messages at the moment - my phone says they are ‘invalid recipient(s)’, but they are valid numbers. It isn’t an iMessage thing. Has anyone else had this problem, and any ideas on how to fix this?
Thanks in advance
Ben
Thanks in advance
Ben
Are you using the standard Messaging app?
Try to find out if this persists if you add/remove the country code for the number.
