According to their website (https://www.tapoutclub.com/products/tap-out-v1-0), the Tap Out is not compatible with “Fairphone models, due to issues with the NFC scanner”. Anyone known with this issue? And perhaps tested it?
Hi.
I have the FP6 and i used the Tap Out with my old phone Nokia XR21 and the NFC worked pretty OK with that. I think any issues I had were because of the phone itself.
Today i tried to setup the Tap Out after owning this phone (FP6) for over half a year.
So the Tap Out simply does not work. It can’t read the NFC chip in the Tap Out thing. When done setting the apps up i tried to tap out and it said to read the NFC it just doesn’t.
I think Fairphone can read it or something because everytime i could get the screen to turn off when trying to get the NFC to read.
So in short: It doesn’t work at the moment.
Fairphone moments is about the same minus the physical NFC reader restriction. What makes it pretty bad if you are trying to restirct your app usage. And you only get 5 apps max in one moment.
*Edited the Fairphone moments part after actually using it and not just comparing the view of it that i recalled from first launch.
