My phone takes 30 minutes or more to get network connection after I restart or change the battery.
If I leave the phone standing for about an hour, everything works fine. This is not just an internet problem (5G/4G etc), it’s the entire network (phone calls, SMS, etc do not work either)
I have reseted network settings including APN. The problem is still the same
If I try to select the network operator manually, it does not work either.
My sim card is 5 years old, but it works fine in a different phone (a Nokia X20)
It happens everywhere, even in other countries
Other devices work fine, even with the same SIM
I tried to lower the 5G, but it has no effect, because it does not connect at all (SMS, calls, etc)
Now Network operators show up quickly, I have had times where it takes quite some time.
At the moment, where I am standing is -114 dBm. With the same SIM card in the same space, a Nokia X20 has -113 dBm 26 asu and it catches network immediately
The fact that your SIM card works fine in another phone unfortunately doesn’t mean anything.
Fairphone is quite sensitive where the SIM card is concerned.
So I would advise you to renew a SIM card that is 5 years old.
I changed to an e-sim, and I am having the same problem as before
Is there any way to figure out what is the phone trying to do when connecting to the network? Aren’t there any more detail logs?
