Hello Fairphoners,
Today I have tried to update my Fairphone 2 to the new 19.08.1 version, but after the installation (with the terminal method in Ubuntu) it could not start properly. The animation is shown, and after a minute it goes into a continuous loop of ‘System UI has stopped’ messages with apart from that just a black screen. I have also tried installing the 19.05.3 and 19.02.1 versions, but I have the same issues with those as well.
On the forum I found this post, in which it was suggested to clear the cache in recovery mode. The described method suggested there does not work on mine. I get a screen with ‘teamwin Recovery Project 3.1.1-0’ and the device does not react to any buttons (or the touchscreen). I have tried to open the manual on recovery mode, but when I try to open it, I am told I am not authorized to see it.
I tried finding out if I can somehow clear the cache via terminal on my computer, but as far as I have found it was only possible in the settings of Fairphone OS (which I couldn’t access because the System UI could start). At this point I thought backing up and a factory reset would be the best option, so I tried to backup with TWRP using the ‘How to use TWRP without flashing it (e.g. for Backup)’ method (sorry I can only put in two links), I used the signed img file and got it to start with fastboot. However, even though I had it constantly hooked up to my 2.4A charger, or my laptop, it turned off. The charge it had when I started the backup first was 77%, after about three hours this was down to 1-5% based on the red LED. Miraculously, it rebooted normally into Fairphone Open OS 19.08.1 after it had charged enough power again. Everything is still there, however I now also have a Google play store now. Probably still a good idea to make a backup now anyway…
Something must have happened during the last step, I’m sure because I accidentally forgot to press volume down before powering it up for fastboot, and it went into the System UI not working loop.
The troubleshooting took me about four hours, but even though I solved it myself (apart from the Google infiltration now, but that’s after my phone’s and my own overnight charging) I thought it’d be better to make a post about it on this forum anyway so it can maybe help others
edit: Yesterday morning I found it could not fully charge overnight, it also gets very hot and battery runs out in about 3 to 3.5 hours of stand-by. I’m still trying to get it to run normally now, probably making a backup of my contacts and going for a factory reset.
