Can anyone shine a light on this. I did give Sygic location premission…
Thanks in advance
Thanks in advance
Which OS are you using (Fairphone OS/ Fairphone Open OS/ LineageOS/ e), and which version/ build?
Hello, im using andoid 7.1.2 build 18.09.2
Sorry i was a bit quick to complane. I’ve had bad expiriences with gps of the FP1. When i sit inside the car everyting os honkydory. Thanks for the reply anyway.
