Hi my Fairfriends!
Iām switching from iPhone to Fairphone and have some questions to the for me, total new Android world.
the clock. Its not visible on the locked screenā¦ how can i set it visable instead of the counter. ( i donāt care how long im offlineā¦)
every pressing shivers the phone! uggā¦ i was so frightend in the first second. so, how can i stop that?
where are the account settings for Mail and calendars?
how do i load music to my phone? - i baught me a SD card and tried to connect the phone over usb. but my mac didnāt show any connection or drive in finder. then i found in setings some SD-Card options but nothing changedā¦ can i make a music folder upon the sd-card with a sd-card-reader and just stick it back in the phone?
Thanks a lot.
Regards, novski
your right. i didnāt recognize that it stays. but its a bit unstable, donāt likeā¦ but well i will have to live with that thenā¦
yep. thanks now all shivering is goneā¦
I will test that. maybe il change sligthly to gmail and google calendarsā¦
now. one question regarding OSX. The transfair tool doesnāt connect with my phone. I tried to unlock and de/replug but i donāt get connection.
Are there any OSX users who can confirm that it should work?
I think youāll have to unlock your phone in order to activate the data transfer.
AND youāll have to config the correct USB mode. Just swipe from the top when USB is connected and there should be an option to change the USB mode. (In German, itās called āFĆ¼r mehr USB-Optionen berĆ¼hrenā). Tap this and check only one of the alternatives. I think MTP should be right.
Thanks for the Replys.
I checked that options in the ātop down-swipeā menu but i donāt get any options here. It doesnāt seam to recognize a conneciton over all. I started my Parallels Win7 and also on Win10 it doesnāt even recognize it in the level of Parallels. So somehow it seams that OSX 10.11.2 does not recognize a connection at all.
Can you make me a printscreen of that connection icon? (by the way how do i make printscreens on Android)
Im still haveing problems geting music on my phoneā¦
I managed to find the MTP option for USB connection:
(For those who are searchingā¦ its not in the dropdown. On my phone its beneth the dropdown like a notification i have to press then a window appears where i can choose between some options. One is MTP.)
Now i sill have the problem that i inserted a larger sdcard with a folder called āmusicā and i wold like to get access from my nice music player. (i choosen the black player from playstoreā¦)
but even in the Amaze File app i donāt see the sdcard.
How can i get access to the music on the sdcardā¦?
I hope it is not too late. Have you already figured out how to access the external sd card? Anyway, here is an explanation for that: Before you can access the external sd card, you have to mount it. You can mount it inside the android settings: Go to settings > storage > External SD card: mount.
There should be different possibilities on how to mount it, I think (Unfortunately, my phone does not have a sdcard slot, so I can not tellā¦).
Once you have mounted the sdcard, it should be accessible in amaze under /storage/sdcard1 , I think.
And if you want to access the external sdcard in your music player, I think there should be a possibility in the music player settings to choose the storage location. Just search there. If the default music player does not have a possibility to play the music from the sdcard, then maybe try another music player.
The website mentioned before is very good for making the transition from Apple to Android https://www.android.com/switch/ although I have a tip for other users re Contacts.
I followed their instructions and was getting nowhere with exporting vCards on Safari, so tried Chrome thinking it was more Google friendly but still couldnāt export my 500 contacts in one go, and I couldnāt face importing them manually (or tinkering with Terminal on my Mac) so I then tried in Firefox. Hey presto all contacts exported in one vCard which I loaded in one batch to Gmail.
I went through the same process. Switching from iphone/ios to FP2/Android is such a pain. In the end it made me set up a brand new google account and leave icloud for good. the total lack of interoperability (?) is quite frustrating. Still not sure what to do about my audiobooksā¦
good luck!
Best,
Paul
Hello
Interestingly, I had lots of trouble doing the opposite, ie putting some audio files on a friendās iphone. I concluded this to be impossible. Can you really have music on an sdcard and play it on an iphone ?
