Switching between programs does not work
Switching between programs has not worked for a long time, or works partially (hides open ones), updates do not help. When rebooting, it works for the first time, but then the problem occurs again.
Could you please provide more detailed information about your issue by sharing:
  • Build version
  • Operating System (OS) version
  • A clear description of the problem you’re experiencing Additionally, it would be very helpful if you could also provide some visual aids to assist with troubleshooting. Like more screenshots or a screen recording
Jqri
Disabled desktop mode over usb display? That known to cause this
The problem was in “Desktop mode”, thanks, this helped.
