Hello, is there a wy to switch the softkeys at the Fairphone 3?
I prefere “back” at the right side instead of the left side at the Fairphone 3 ;-).
No, it is not possible. You should get a Samsung if you want it the wrong way round.
PS.: There is a workaround (with a side-effect): Go to #dic:developeroptions > Force RTL layout. This will justify the screen’s content to the right and will switch the positions of the back and the task manager button
Android 9 does not offer this option. Maybe this app works, I have not tried it myself:
This apps requires these permissions:
Diese App kann auf Folgendes zugreifen:
Speicher
- modify or delete the contents of your USB storage
- read the contents of your USB storage
Fotos/Medien/Dateien
Sonstiges
- modify secure system settings
- receive data from Internet
- bind to an accessibility service
- modify system settings
- full network access
- prevent device from sleeping
- view network connections
- run at startup
- expand/collapse status bar
Ok, i can deal with it.
Thanks for the helpful informations.
