Switch e/OS launcher away from Bliss?
Is there any smooth way to use Trebuchet (LineageOS) oder Quickstep (CalyxOS) as launcher on e/OS? The default launcher is missing features and I really dislike it’s “simplicity”. I even don’t manage to see a list of installed apps, when swiping up or beeing able to delete caches or stop apps, when long pressing on app icons… disgusting.
Thank you,
Singu
Try the fossify launcher instead
If your launcher of choice is there in installable form for any Android OS, feel free to try it, there’s a ton of launchers out there.
But regardless of the launcher you choose, don’t get tempted to uninstall Bliss, as on /e/OS it is the stock launcher, and since Android 9 (Pie) parts of the stock launcher tend to still get used for things even if you use a different launcher as your default …
My problem is the concrete question on how to use the 2 launchers I mentioned :). I couldn’t find any easy way as they are not available in the app stores?
This looks really nice and feels well known, I guess this is it!
I’ve been using fossify for a few weeks now and I like it. Just 2 glitches I observed:
  1. When uninstalling apps which are grouped on home screen in a folder sometimes removes the folder and as a result all app links on home screen.
  2. Swiping between desktops seems a little sluggish (with >60 Hz. display and smooth display setting enabled).
Are these known issues? Thanks, Singu
