Strange notification every 5 seconds (animation, beep, Vibration)
On my new Fairphone, I get a strange notification every 5 Seconds. It is a beep, a vibration and a point cloud animation moving from bottom of the screen to the top (see attached Image). What is it? How can I deactivate it?
Is you phone not plugged into a charger? this is the charging started notification. Maybe the cable isnt plugged in correctly.
Yes, that Is my problem here. Thanks!
