at the risk of having missed the solution that already deals with my problem:
My FP1 told me that there is insufficient storage for installing app updates. So I have tried to install the storage upgrade several times (WiFi activated) but after rebooting I can still see one internal storage and one telephone storage. I also have an SD card that is virtually empty.
Well, you might have to install Fairphone OS first if you havenât got it installed yet. I guess Fairphoneâs storage update might not work with stock Android. @paulakreuzer ?
Also be prepared that you might have to install (Fairphone OS) manually, i.e. from your SD card in recovery mode.
Okay, the Fairphone Updater says that my current version is Fairphone Kola Nut 1.8.7. So I must have Fairphone OS, right? If yes, there must be another problem. Supposedly, my storage is running out and some functions are not working correctly anymore âŠ
Sorry if this bugs you, but just to avoid any misunderstanding: When you say you tried updating manually, you went through recovery mode and applied the storage upgrade file (while being in recovery mode) that was saved on your SD card?
Since the Unified Storage Upgrader deletes all files on your phone anyways, you might as well try wiping data before applying the Upgrader. Does this help?
I tried everything that is adviced to get get one partition for koala nut, but still have two partitions so cannot install the required update for Whatsapp because there is not enough space in internal storage (there is 101 MB free, I thought this should be enough). Is it advisable to go back to factory settings ?
Stefan thank you for your help. Kola or Koala my FP1 seems ânutsâ : even factory reset doesnât work. Possibly the reason why the unified storageprogram also doesnât work. Hope for a solution and can be happy again with my FP
