Hi all,
I’m experiencing spurious reboot when running some common application (twitter, Clash of Clans, …).
I’m not the only one having this problem, but none of the workarounds I found in the forum helps: removed SD card, disable 4G, upgrade…
Currenlty running Fairphone OS 17.11.2: Android 6.0.1, kernel 3.4.0.
One of the things I notice is that the phone is, sometimes, really hot in the back. I installed cpu-Z and most of the sensors report a temperature between 55 and 60.
So, I’d like to ask if that temperature is high and it could be the cause for the reboots or I have to look other things.
I got the phone one month ago…
Thanks in advance,
Arnau
