Found that when making calls the volume is really low even if speaker is selected. The setting is set to high on the volume control. Sometimes during a call it just goes really load without warning, almost as if it has a loose connection. I have stripped down phone cleaned and reassembled but it made no difference.
Which Fairphone with what software are you talking about?
Thank you.
Its a FP2 running android 10.
