Sleeping mode in 2 minutes
Normally I want my FP2 to enter sleeping mode after 2 minutes. But sometimes I need to have an active screen for longer. Since Android 6.0, even when I choose (in screen settings) sleeping mode to be entered after 10 minutes or so, the screen always turns black after the same 2 minutes.
My FP2 turns to sleep mode after 25 sec regardless of all screen settings I change!
This is very annoying!
I turned off energy saving, nothing helps.
My wife has also a FP2 and I compared settings, I found no difference…
I have the same problem. Fairphone goes into sleep mode after 30s since Android 6 update. No matter which settings I use. At the moment the only help is an APP called “Screebl” which blocks the sleep mode depending on the angle the phone is held.
This topic was automatically closed after 182 days. New replies are no longer allowed.
