Is it possible to have different ringtone volumes on incoming calls and messages. I would like it to just vibrate when I receive a message, but have it ring loudly when receiving an incoming call.
I don’t think so. ringtone-, text messages- and notification-volumes are linked. maybe there are apps that can do that.
the only thing i can think of is you can choose a more discrete notification sound for your text messages or maybe, if you really want texts to be silent - you could use a silent audio file as your notification sound.
I think it’s possible.
- open the sms app
- tap settings
- tap notifications (Benachrichtigungen)
- check “vibrate”
- choose “none” from “choose ringtone”
Thank you for the answer. That worked.
