I’m experiencing a persistent issue where Signal does not connect over mobile data on my Fairphone 5 running /e/OS. The app works perfectly when connected to Wi-Fi, but fails to send or receive messages when using mobile data—even though other apps (browser, email, etc.) work fine.
Troubleshooting already attempted:
Verified correct APN settings for Orange Belgium
Disabled Advanced Privacy features in /e/OS (Hide My IP, Tracker Blocking).
Ensured Signal has permission to use mobile data and background data.
Cleared Signal cache.
Tested with different network modes (4G only, 5G disabled).
Confirmed mobile data works for other apps.
Deleted and reinstalled Signal
Can anybody help? Thanks in advance!
Volker
September 12, 2025, 8:41pm
2
Quite an old topic:
opened 05:58PM - 28 Feb 22 UTC
closed 12:45PM - 19 Sep 22 UTC
wontfix
- [X] I have searched open and closed issues for duplicates
- [X] I am submitti… ng a bug report for existing functionality that does not work as intended
- [X] I have read https://github.com/signalapp/Signal-Android/wiki/Submitting-useful-bug-reports
- [x] This isn't a feature request or a discussion topic
### Bug description
This is a follow up from #11839. The issue was closed and, as requested, I am opening a new one to solve this problem, that seems like is not caused by mobile providers, even if the bug seems the same.
Signal is only working on WiFi for my girlfriend, that is using ho.mobile on an Android phone. I am using Vodafone IT on an iPhone and everything works perfectly.
She cannot send or receive any message or media, Signal is completely unusable while connected to the mobile network. This has been going on for months and it is really hard to justify keeping using Signal. I really do not want to go back to Telegram or WA, please help me solve this.
### Steps to reproduce
- Send a message over cellular, does not work
- Connect to Wifi, message is received
- Send messages over WiFi, everything keeps working
**Actual result:** Nothing is sent or received over cellular data
**Expected result:** Everything should work over cellular like over WiFi
### Device info
**Device:** Google Pixel 4a
**Android version:** Latest
**Signal version:** Latest
### Link to debug log
https://debuglogs.org/android/5.32.7/1c40e951fd80cb3b378859bd6f23ae1a1154af835fdf0f70a6afb06d8bc72c8a
Still it contains two ideas which you might try out…:
1.) try using signal-foss
2.) adding com.google.android.gms to a deviceidle whitelist
I saw this in the Murena forum.
Après avoir pu envoyer/recevoir des messages (même que texte) avec Signal, ayant des soucis de connexion internet pour le navigateur Brave, j’ai modifié des paramètres et Signal n’arrive plus à envoyer/recevoir de message s’il n’y a que les...
The solution was to turn off the following parameter
Settings > Network and Internet > SIMs > [your SIM] > Roaming
system
Closed
March 12, 2026, 6:58am
4
