Signal links do not transfer from slave to master
When I answer a message in Signal, normally a link to the original message is seen above the reply and by clicking on it you can follow the thread. When I type the answer on my FP5, the links are present on the master and slaves as well. However, when I type the answer on a slave (tablet, PC, iPad), Signal on my FP5 provides the picture of the original message, but no link; instead it adds “Original message not found". However on the other slaves the link is present and working.
What can be gone wrong here and how can this be fixed?
Maybe ask Signal. This does not seem to be an issue of the phone, but rather an app issue.
Thanks. In the meantime, the problem has solved auto. A friend of mine had the same issue though.
