@Stefan: this is how it looks on the testforum…as you can see…only body is affected…
If you guys have decided what colour you want let me know…
Indeed I’d make it a little lighter. Something like: #E5FFE0
Yeah that looks great. Let’s use that.
I think it’s too light. I barely see it on my non-retina screen.
Don’t we all have non-retina displays?
Or should we go for a different color after all? Red-green blindness is quite common. @Chris_R?
Did you see all the iMacs in the Fairphone office? ![]()
I suggest #e0ffe0.
According to ColorHexa’s Color Blindness Simulator, the colour will look different. But any colour will stand out, and that’s our goal here, right?
1st: I think a bit more colour would be fine.
2nd: Red green blindness would be a problem only, if we have some text in red or a red background to mark other texts. As long as there is green only, it should not matter, should it?
Oh yeah of course.
Well I think
Looks nice. ![]()
Ok changed it to: #e0ffe0
Let me know if this is ok or not…
Ok to be honest actually seeing the color as a #wiki background I do think it should be lighter after all.
I’m pretty sure it was much lighter before.
Also when you load a wiki post it starts off as staff-blue and then slowly turns white (like every other post) before finally turning green. Is it possible to disable that animation for wikis?
PS: Especially light grey text and grey quotes don’t look good on such a strong background color.
In my Fairphone 1 I’m still using the old theme and there is no green background at all.
I need to check that
ehm I only changed it on the new theme…I can change it everywhere…please hold on
Just for reference for everybody who wants to quickly check out the current color:
This is a wiki post.
And this is what some things with grey color look in a wiki:
Quote:
Mention:
Likes, share button etc:
I’d actually prefer the lightest one of those three options.
Discourse 1.5/1.6 used #408040, which is quite dark. I’m assuming the background was faded out a bit, but can’t find that quickly enough.
Yeah I believe that’s the color of the edit-symbol in the top right corner of a wiki.
Is that a typo? I believe you mean #covfefe
