Maybe you can do this with an app?
or
for eg.
or
for eg.
The Samsung was standard Android. It was a Note 3 and actually was still working fine. Getting under the Google radar is what appealed to me, as well as the increasing number of incompatible apps.
Thanks! I’ll investigate these apps! Fingers crossed!
/e/OS is available for a range of Note 3s (detailed models supported are given when you hover over or follow the different “Galaxy Note 3” links in the device list, so if your Note 3 is one of the supported models and if you feel adventurous enough to try, you could find out whether the issue is the fault of /e/OS rather than the phone … and you could have your still working Note 3 degoogled , although only the LTE models listed with /e/OS R will have a future with security updates.
I installed both apps but couldn’t see how to sync the contacts. However, I found this article and following it worked for me!
