Installed a micro SD card a few days ago with stuff already on it so left it as external. Since then had problems with proximity sensor not working so doing crazy things with my ear while in call. Then (after calibrating the sensor) things got worse and making a call caused the phone to reboot. After slight brainwave have ejected SD card and these problems seem to have gone away… I daren’t say stopped. Any similar issues or possible reasons why? It is a pretty old SD card. I have a call in to support as well and have updated that. #howtowasteyourSaturday
I suggest you take help from memory card data recovery where you will get proper suggestion on this issue. If your SD card is causing such irritating issues, just format it following a backup of the files.
