On the old FP Open, I was able to solve SD card problems (apps couldn’t write on it) with SDfix from the Play Store.
On the current version, this doesn’t work. There is a Marshmallow version of that app but it has no effect. With this problem, I cannot have Titanium Backup write on my SD card and subsequently don’t want to run an update.
Related question: If I reformat the SD card as internal storage (which would supposedly fix the problem), can I write on it from my PC?
Yes, it is accessible (using MTP) after migrating your data from internal storage to the SD card. This will also disable USB access to the internal storage.
USB access to both internal storage and SD card is only possible in portable mode, but, as you noticed, this can cause compatibility issues with some apps.
