Screen pixelated after installing camera upgrade
I installed the camera upgrade for fairphone 3 now the display is pixelated and i cant use the phone!
Unfortunately i managed to knacker the heads of 2 of the screws so cant take it out again.
Any advice very welcome!!
The pixelated screen may be down to the display not being seated properly. Try pressing on the right of the screen from the front about a third of the way up.
RE: The screw heads, I imagine this was in extraction as that is when pressure is required to overcome the torque. Removing may work with enough torque or with adding some filling to aid grip. Otherwise you can try a commercial shop, or maybe a #fairphoneangel
Try and get a few new screws meanwhile
