Screen goes bananas for seemingly no reason
Hi all,
previously, do not remember if it was before the last or second to last update (probably the latter), my FP2 got into the habit of flickering the screen and turning all sorts of things on, like settings for different things. It stopped, but has now started again, and it does not seem to be caused by any specific app. It happens both when plugged and unplogged, and I do not think it has to do with static electricity. Only thing that helps temporarily is removing the battery (it often cannot even be shut down normally).
I just changed the “press and hold” in Settings from short to medium, but it would still be appreciated if the screen problems was better noticed by the developers.
(Moderators: please combine this with any previous thread, if you like, it only seemed to fit within a locked one.)
According to the official troubleshooting tool here is what you should try:
  • disassemble the screen and clean the connectors
  • update your phone (you can do it manually even if the screen doesn’t work.
  • and adjust touch and hold delay as you already did
If none of that works contact support with this info:
Subject: “Ghost touches”
Description: “My display suffers from unintentional touch inputs, or “ghost touches”. I confirm that my shipping address is correct.
Please see attached the sample video and advise how to proceed further.”
your order number
your phone’s IMEI
attach a video of your Fairphone 2 suffering from ghost touches
This topic was automatically closed 183 days after the last reply. New replies are no longer allowed.
