Screen comes on when charging cable disconnected
When the charging cable is disconnected my Fairphone 6 screen comes on. Is there an option to disable this so the screen doesn’t come on?
Yes, there is. You’re welcome.
“Wake on plug” in the display settings
Thanks for the reply. However, there isn’t a “wake on plug” option in my display settings. Might it have another name? I had looked at all these settings before posting this question.
Oh, sorry. I believed this was a standard setting for stock Android too.
I only have /e/os. The setting is at the very bottom of Settings->Display
No problem, thanks for the suggestion. I’ve had another look at all the options under “display” in Android 16 but there doesn’t seem to be anything similar
