Screen brightness randomly limited to only about ~50%
Even if is not a wide spread issue, is an issue reported by several people it seems.
It is also a major problem, at least for me. For example my FP5 is not usable in sunny day as gps with Google map, the screen is too dark
Yes I understand and would repeat
If not already done so. As its not a wide spread issue everyone facing it need to contact support, else I doubt it will ever be fixed and still might be hardware issue.
I too confirm, with disabled “Display/DC Dimming” problem not occurred…
Indeed, I didn’t get this connection until now. Disabled DC dimming and my first trials look promising. That might also explain why not so many people are affected.
Had DC dimming enabled, randomly jumping around brightness, making the device unusable outside. Even just laying on my desk the brightness would jump around. Now disabled ‘DC Dimming’, lets see how that goes.
I just looked at my settings and had dc dimming enabled.
Disabled it myself too. I hope it fixes it
No longer constantly jumping around, buttt now I have a new one where sometimes it goes to minimum brightness for no reason. An improvement still, but clearly it still doesn’t really work.
A post was merged into an existing topic: FP5 brightness randomly reduces
Is this issue still happening? I enabled DC dimming again with the Android 14 update, so far I haven’t seen the issue. But it may be too soon to tell.
Its def not fixed and being worked on…
Have you seen the issue in Android 14? Not everything is reported back by FP or included in their change logs. But I’ll leave it as is for a few weeks and report back later. As I said, it’s probably too soon to say anything, but if someone sees the issue still with A14, then please let us know.
I have feedback from them that its being worked on and the feedback is from 24th June. I know that they dont mention eveything in change logs.
Unfortunately yes, so I turned off DC dimming again (at least this works reliably).
A post was merged into an existing topic: Auto screen brightness doesn’t work in low light again (Android 14 Update)
