That’s strange… I tried multiple times and it works!!
Works fine here.
Works fine here.
yeah, pls look at my replies in the thread ^^
i accidanltly installed your first build from 19.0. it seems that your current build suffers the same ‘problem’ like in Official LineageOS 18.1 for Fairphone 3/Fairphone 3+ - #408 by TeamB58 . I unlooked the bootloader again, and now it did install without problems ^^v
I’ve been using this ROM for a couples days and want to say thank you to @TeamB58 for bringing Android 12 to the FP3
Location was not working at first but the new build fixed the issue
The only thing that is not working now is the Rakutten Viki app, I get a black screen when playing a video. I guess this is because this ROM has no DRM. Does someone know a way to install DRM on Android ?
Good catch.
DRM is indeed disabled currently. I mean, the proprietary widevine blobs are not included. I am just waiting for official Android 11 release because it might be tricky to use Android 10 DRM/widevine blobs for Android 12.
Now that the boot issue is resolved in LineageOS 18.1, I have ported to 19.1 as well. I’ll share the next build when the May SPL has been merged. Could be probably by next Monday then.
Thanks for all your support.
Enabled here: https://review.lineageos.org/c/LineageOS/android_device_fairphone_FP3/+/331360
Should be available in the first release.
Hi All,
Official LineageOS 19 is getting delayed because of the fingerprint issue:
So,
What to do now?
0 voters
Addressing this issue might take longer time because neither @dk1978 nor I could get to the root cause of this issue.
Choice is yours now.
I’m not sure i understand this correctly. Isn’t it normal that you first have to unlock with your pin and only afterwards finger print works? Or doesn’t it work at all after reboot?
That’s right. But it isn’t working even after an initial unlock.
There seems to be some issue with either firmware file or the library.
The fingerprint sensor has never work reliably for me even on stock firmware so I don’t care
Hey! Is it the same, when doing an upgrade installation, where the fingerprints are already registered (no clean installation)? For me, fingerprint sensor works quite good, but I can live without it for a few months.
Problem is, if it becomes official, many users would probably see this as a basic feature and be frustrated.
The FP sensor is not a mandatory part for the phone to work, but it’s also used to make the use of a password vault such as Bitwarden, or of a 2FA keys manager such as Aegis, much more convenient.
So, why not releasing it, but with a huge red-letters warning.
Hopefully the bug gets solved soon.
Hi All,
I am very happy to inform you all that the fingerprint issue is now resolved. Special thanks to @Quallenauge for pointing out the issue.
So, we might go official as soon as it’s merged in frameworks.
Thanks.
Hopefully the last update for the Unofficial topic.
Thank you for all you patience and sorry for the delay.
TeamB58.
For those who don’t know, lineage 19 is officially available for FP3 LineageOS Downloads
I can confirm that DRM is enabled
Official topic here:
