[ROM][UNOFFICIAL] LineageOS 16.0 for FP3
That’s correct, there is no FM radio App in Fairphone OS at the moment.
But the SoC has the capability, and FM radio was apparently included in initial specs that went out to resellers, only to be omitted in later specs, so there was speculation here from the start whether FM radio could be perhaps brought to life via software somehow, or whether there was still hardware missing, e.g. some antenna wiring … see the topic I linked to.
I think most LOS ported devices still include vendor binaries. As you stated, this is pretty usual.
Unfortunately I don’t know the requirements for an official LOS device, however there are some. E.g. there is a Wiki page describing how to add a device there. Furthermore I think that I read somewhere that there are some rules about maintaining the device tree.
Anyway first we need to get to a stable state before we can check to make it an official version. :wink:
Usually the build scripts should complain if proprietary files are missing. I mean the extract script prints a message, but the build fails with an error then. At least this was my experience. Did you add some more checks in your script?
I randomly fell over this and posted my findings in the thread. However I also assume that there is a reason why they removed it from the stock firmware. And I totally agree to @dk1978 that we should remove it for now. To really make sure I think some hardware expert needs to check for that or maybe we can get some details on that from Fairphone themselves.
Hey @michlx,
you have access to the UART, right? Do you see messages from the bootloader here?
I’m currently checking for flashing with TWRP. However it seems like bootloader rejects to boot the slot afterwards for some reason.
Could those repos be of help?
The kernel repo interestingly has original commits from Arima in there (but also my fixup commit to make the dtbs build :smiley: ), so they got some (previously) internal git repo from Fairphone.
Seems like it was a cooperation / partnership this time https://twitter.com/gael_duval/status/1255567703089336320?s=19
Hi, sorry for the late reply. Good question, I sometimes run ‘make clean’, especially when I observe weird things :slight_smile: . Make clean also seems to delete all contents of the out folder
Hi Max_S, I created that script as kind of integrity check. Strangely, I did not observe build errors. Though, I might have overlooked a warning somewhere. What kind of additional checks do you have in mind? I do not yet check the sha1sums, but that should be no issue to add.
Sure, the UART is still connected. I just need some time to prepare to record stuff again.
Above, in post 23 is a link to a gist that shows how it looks like and the lines that are necessary in the kernel config.
Just drop me a message what I can try for you.
Yes, definitely. I’ll try to build LOS with it. Looks really great, they have important security features enabled as well like Android-Verified-Boot and SELinux.
Good that Fairphone supported the development. However would have been nice if they had published some details about that. But hey, finally we have something available we also can build upon :slightly_smiling_face:
I’m not totally sure, but it also seems that they officially signed the /e/ images. Otherwise I would expect that locking the bootloader would make it fail to boot. However I never tried, maybe the bootloader doesn’t check the signature or supports certificate pinning or something like that. I’ll try to check for that.
Yes, maybe some integrity check with hashes etc.
The build stopped for me with an error message when files from proprietary-files.txt were not available.
Oh yes, and it looks like there is some output from the bootloader. Lines like that are interesting here:
[21:46:24:644] [1840] avb_slot_verify.c[1840] :[1840] 417[1840] : DEBUG: [1840] Loading vbmeta struct from partition '[1840] vbmeta_b[1850] '.␍␊
[21:46:24:644] [1850] avb_vbmeta_image.c[1850] :[1850] 226[1850] : ERROR: [1850] Hash does not match!␍␊
[21:46:24:644] [1850] avb_slot_verify.c[1860] :[1860] 539[1860] : ERROR: [1860] vbmeta_b[1860] : Error verifying vbmeta image: [1860] HASH_MISMATCH[1870] ␍␊
[21:46:24:644] [1870] ReadRollbackIndex Location 0, RollbackIndex 0␍␊
[21:46:24:644] [1870] avb_slot_verify.c[1870] :[1870] 417[1870] : DEBUG: [1880] Loading vbmeta struct from partition '[1880] system_b[1880] '.␍␊
[21:46:24:689] [1880] negative Offset (-64) converted to (0xbfffffc0) ␍␊
[21:46:24:689] [1890] read from system_b, 0x40 bytes at Offset 0xbfffffc0, partition size 3849453568␍␊
[21:46:24:689] [1890] StartBlock 0x5fffff, ReadOffset 0x1c0, read_size 0x40␍␊
[21:46:24:689] [1900] read from system_b, 0x740 bytes at Offset 0xbff5b000, partition size 3849453568␍␊
[21:46:24:689] [1910] LastBlock 0x5ffadb, ReadOffset 0x0, read_size 0x140␍␊
[21:46:24:689] [1920] ReadRollbackIndex Location 2, RollbackIndex 0␍␊
[21:46:24:715] [1920] avb_slot_verify.c[1920] :[1920] 157[1920] : DEBUG: [1920] boot_b[1930] : Loading entire partition.␍␊
[21:46:24:843] [2070] avb_slot_verify.c[2070] :[2070] 232[2070] : ERROR: [2070] boot_b[2080] : Hash of data does not match digest in descriptor.␍␊
[21:46:24:890] [2080] avb_slot_verify.c[2080] :[2080] 157[2080] : DEBUG: [2090] dtbo_b[2090] : Loading entire partition.␍␊
[21:46:24:890] [2100] avb_slot_verify.c[2100] :[2100] 232[2100] : ERROR: [2100] dtbo_b[2100] : Hash of data does not match digest in descriptor.␍␊
[21:46:24:890] [2110] system_b uuid: 68bc91e6-9723-e5d0-1210-96dcc78c4f05␍␊
[21:46:24:890] [2110] boot_b uuid: 813695bb-3859-9b75-5afd-a3eb6165e68d␍␊
[21:46:24:890] [2120] vbmeta_b uuid: 4617542d-6902-0abe-e740-2c209d448ea4␍␊
[21:46:24:933] [2120] State: Unlocked, AvbSlotVerify returned ERROR_VERIFICATION, continue boot␍␊
However I guess it is caused by vbmeta we need to build, maybe with AVB enabled. The /e/ guys did that, so hopefully we can adapt that. If still not working I’ll come back to you.
After some night hours I got LOS successfully building with the /e/ config. Some small changes were required, e.g. in extracting the binaries. Great thing is that I was able to flash it with TWRP from @k4y0z now. Seems like my expectation with the vbmeta image was correct. Checking the image from stock firmware, /e/ and my build one with avbtool it seems like the test key is used for all of them:
Public key (sha1): cdbb77177f731920bbe0a0f94f84d9038ae0617d
This would also explain why bootloader can be locked with it.
Ear speaker is again not working with it. I think most probably because they use a different qcom hardware branch. I’ll try to switch to that and build again tomorrow.
I uploaded the built package and the images to github. Maybe someone want to give it a try.
I think we should go with that config as a base from now. The /e/ guys did a great job. And this would also allow to sync between the repos more easily.
@dk1978 What do you think?
@Max_S:
I agree. From what I could judge, everything in the device tree looks clean and well thought through. The /e/ people obviously got some “inside” knowledge such as Arima code contributions that we can make use of.
Hi guys,
I just updated my FP3 to the 0118 release. I examined the changes to the vendor blobs and stumbled over this change to what appears to be a list of emergency numbers of all things:
diff --git a/proprietary/vendor/radio/qcril_database/upgrade/0_initial.sql b/proprietary/vendor/radio/qcril_database/upgrade/0_initial.sql
index a06eba8..1d40d52 100644
--- a/proprietary/vendor/radio/qcril_database/upgrade/0_initial.sql
+++ b/proprietary/vendor/radio/qcril_database/upgrade/0_initial.sql
@@ -272,6 +272,9 @@ INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('231','01','911','','');
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('231','01','112','','');
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('214','03','112','','');
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('214','03','911','','');
+/*<20200318-LindaGuo,Add emergency number 016 for Orange ES. */
+INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('214','03','016','','');
+/*>20200318-LindaGuo. */
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('208','01','911','','');
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('208','01','112','','');
 INSERT INTO qcril_emergency_source_mcc_mnc_table VALUES('334','020','060','','');
If I interpret this correctly, then someone updated an emergency call number for Spain as 016. I don’t know about Spanish emergency numbers, but Google tells me 061 is an emergency number for health emergencies. Could this be a serious typo? Does anyone have more ideas?
I finally got it built and installed! It has been long for different reasons, but I’m ready now.
I have coding skills (that’s my job), but not much Andoid OS knowledge.
My FP3 is my only phone and must remain in a working state (or in a state that can revert to a working state).
Given the points above, I’m ready to help, just let me know.
I’m currently rebuilding with signature spoofing patch, if anyone is interested in having this patch, just tell me.
@pipoprods:
you are welcome to help. If you need a working fallback for your phone, then I suggest you keep the stock Fairphone image on one slot and an experimental system like /e/ or LineageOS on the other slot. This should work, provided you take care to back up and restore your userdata partition which cannot easily be shared between the two systems.
Why don’t you just google this? 016 is indeed a legitimate emergency number in Spain, see
https://violenciagenero.igualdad.gob.es/informacionUtil/recursos/telefono016/home.htm
Trust me - I did but did not find that page. Only pages about 061. That’s why I wrote here instead of troubling support, knowing there are smart people here. :grinning:
Anyway thanks for the info.
You definitely need to have good backups in that case. Factory reset is required very regular unfortunately, e.g. when you switch between stock, /e/ and LOS. Also I’m unsure how device encryption influences that.
However I hope that we now come to a more stable state where we can switch between different LOS versions on the slots and don’t need to reset data all the time. I also want to start using the FP3 for daily usage and don’t want to order any more spare parts for my FP2 :smile:
Maybe you can try to build with the microg docker container. That would be one of my next steps at least :wink:
Ok. How should we proceed on that? I’d try to get the branch to a buildable and good state first now. Should we then merge it to the lineage-16.0 branch or should we rename it and replace it completely? I mean it’s a lot of changes and I would instead try to move our README etc. to that new tree.
