Removing SD card?
This is really silly, I can’t figure out how to get my SD card out. There’s two bumps in the way of it just sliding out, and I can’t pull at it from an angle where it can pass them. Do I need tweezers??? Is there a magic word I’m missing?
Indeed, it’s not that easy. I put a small piece of paper below the SD card and then try to pull it out. :wink:
yes, tweezers work. but be careful, it’s darn easy to destroy your sd card that way. try to remove it without any bending, pulling it over the 2 bumps as horizontally as possible. same procedure works to insert the sd card again.
I ended up using a credit card as a ramp to get over the bumps. Seems like it’d be easy to break something that way, though…
