I bought a second-hand Fairphone and I would like to add its serial number to “My serial numbers” on my profile, unfortunately I couldn’t find the procedure to do so. Is this even possible?
I am not sure if this is the right place to post this question but some of you who bought second-hand Fairphones might have been in a similar situation and found an answer already.
I think Fairphone support is able to add serial numbers to the shop. But I don’t know if they will do so, so we have to wait for another user who already tried this or you will have to try yourself.
But I don’t know of a use case where you really need that entry.
