Sorry if you mentioned this somewhere and I don’t recall or saw it, but for reference if others want to check the problem out … Is your performance profile set to “Efficiency” already? …
I thought the “Limit maximum CPU power” effect of this setting should be worth some attention in cases of overheating and reboots.
Interesting. Last year when I drove to Italy for my holidays I had the phone navigating and charging at medium brightness for the whole ride (around nine hours) without discharging. It rather charged, therefore power consumption was lower than power input.
I guess there are far too many factors to consider why your phone behaves this way. I’m sorry that you have to part ways with your Fairphone for this reason but I can absolutely understand your decision.
Hi, I have reboots while using OsmAnd in cars. Even when not charging the phone. Even with LineageOS 15.1.
I kept a LineageOS 14.1 up to date before that and it worsen in the last 2 to 3 months.
I just installed Logcat Reader to constantly dump logs in a files and will provide some logcat here.
Regarding performance settings, I experienced that OsmAnd was enable to reroute live after a mistake if using the most powersaving profile, so I was using the balanced one. I’ll try the “Rapid” one for the coming days, and may try the “Most performance” one after that.
[24h later, no reboots so far, after 2x20 minutes usage of OsmAnd ; I wanted to share some hope about this performance profile tweak]
I also have reboots with OsmAnd but also with Sygic GPS Navigation.
I just have GPS enabled during the reboots, and nothing else : no bluetooth, no GSM, ni wifi…
I had the issue with LineageOS 14.1 and now I’m under 15.1 : the issue is still there as described by the topic author.
In my case I always found the FP2 very hot during reboot. It’s look like a hardware protection such we can find on laptop with burning CPU
I got a reboot after the 1st 2h trip guided by OsmAnd, a few minutes after I ended the session (cause I was arrived). I lost that log because Logcat Reader app is loosing logs when the phone reboots. So I now capture my logcats this way:
I got another no-GPS reboot the day after.
And then a reboot during OsmAnd guiding (with VLC music in background). The phone cut the music, becoming unresponsive for a few second, and then reboots (I suspect some kind of watch dog software impatient to reboot at the 1st sign of slowness).
The files are XZ compressed texts, appended with a .ttf extension because of surprisingly naïve limitation of this forum about allowed extensions in uploads.
I hope those files will be usable by @chrmhoffmann for instance. Please correct me if I’m doing something wrong in the process.
I also have reboots while using GPS apps in car, same as @siltaar under LineageOS 14.1 and 15.1.
Mostly I use “Blitzer.de” speedlimit warning (standalone, no other apps activly running),
but also “Here WeGo” navigation, charging was allways necassary.
And the “running time” of navigation doesn’t matter, sometimes the FP2 reboots after 10min, sometimes after 2hours.
I changed the power adapter (12V/USB) from cheap to powerful, so I can exclude the cause of a weak (or changing) power consumption.
I’m concerned not having had any feedback from posted logs since 4 months, nor any improvement while updating LineageOS. Even with recent updates, the phone still reboot twice a day and too many times by trips while using OSMand to rely on it.
It can also reboot while writing an SMS in Silence, for what I notice.
Contrary to what I wrote before, changing the Parameters->Battery->Power efficiency switch don’t change anything.
I wonder if switching back to FPOOS would allow for a reliable phone again. I think I’ll try.
