Hi, I have the last update of system; before I rooted my fairphone so with the last update I lost it.
But the problem is that now, when I’m playing clash royale, my phone rebbot very often, it’s very ennoying, do you know how to fix it please?
Thanks a lot
You could attempt to root your phone again.
Tanks, do you think it’s better than upgrade to thé advanced version?
I would advise you to first root your phone and see if that solves your problem.
OK,thanks… I will tell you if it works
If your phone works normal after rooting when you play Clash Royale, then you must ask yourself do I really want to play Clash Royale, if it demands a rooted phone.
Non it doesn’t need root, my friends, who have un rooted phones such as Samsung can play clash royale. I juste rooted the phone because root adds many possibilities
You might have a random reboot issue not linked to Clash Royal in particular:
