The rounded glass cover over the rear camera and flash keeps falling off. I assume it is stuck on with double-sided adhesive tape, which I could replace with some effort, but there are also two little knobs or plastic protrusions. Are they designed to hold it in place? What’s the best approach? Thanks.
Now 4 months later, the camera & flash cover fell off and I didn’t find it. Now some dirt has got into the camera lens and I can’t shift it by cleaning the lens externally.
Is there any way to clean it better that will work?
If not, is there a second-hand parts market where I could buy a salvaged FP3 camera?
You could take a look at the Market category.
Right here on the discussion board. How amazing is that? Thank you…
Hmmm… I have the same issue, and looked at the Market posts linked above, and it seems most posts are old and no responses are possible anymore… and I see no way to send a DM to the sellers (EDIT: yet, as I just registered, of course). How did you manage to find one ? Thanks in advance
