QuickStep Unusable
Since installing the latest update on my Fairphone 5, Quickstep has been unusable.
I can’t put shortcuts or widgets on the home screen.
For Breezy Weather, for example, it slides the empty widget (with edit option) to the top left and disappears immediately.
Muzei no longer works either.
I have already forced stop, clean all datas, no results.
My phone is not branded with any operator (bought on fairphone site)
Is there a solution other than replacing the launcher with a more reliable one (Fossify Launcher, for example)?
Thanks for your answers
I have the same problem.
Also with some other launchers i try
Could you both define the exact OS Version you have installed?
And @Georg_Funke did you try to clear data and storage of Quickstep even if you use another launcher?
I have the latest version of FairphoneOS : FP5.VT2K…20251222.
I’m now using Fossify Launcher with no problems for month.
QuickStep is still on the dark side :wink:
Fairphone 5 with Android 15 FP5.VT2K.C.076.20251222.
No i don’t clear data on Quickstep, because i want an usable laucher.
On other laucher i clear data or install freshly
