Oh noez…
* HPROF
→ Fairphone 2 Launcher | F-Droid - Free and Open Source Android App Repository
Yes, that’s a known issue on the F-Droid side. However, when they update the web metadata from our repo, that’d be solved. It’s not happening on the Android client, BTW.
I installed the launcher right after publication on LineageOS with microg, but none of the apps has been moved to the inactive section so far. Am I missing something?
I have it on my FP1 and even though I use another launcher (KISS), the inactive section is filled with 75% of my apps. It took a couple of days until apps went to that section, though.
Hm, I don’t know exactly when it was published, but one or two days after, I installed it. So something seems to be ging wrong. Is this the right thread or should I open a new one?
I’m not one of the maintainers, but it might be most efficient if you’d open a new issue report on Github:
Did it, thank you.
https://github.com/WeAreFairphone/FP2-Launcher/issues/32
