[Project Terminated] Divest OS on the Fairphones
Thanks to all of your help, I managed to finally get the fastboot working by the updating driver.
I am new to android as a whole, so I appreciate your patience and advice in these matters greatly.
One problem I faced is what exactly am I to do with the files given to us,
do I just need to download these on my laptop (yes windows 10)?
Also for the Fairphone version thing, I remember seeing on their website to be cautious of the anti-rollback feature, but I am still not too sure how to act accordingly, what did you guys do?
Thanks for all the help, and I’m looking forward to speaking to you guys again.
Click the linked ā€œinstall methodā€
I read that Divest does not have any Network location provider. Is it possible to add some on my own? (Like UnifiedNLP) or is there something which prevents this technically?
Used CalyxOS on the FP4 and somehow used to get a quicker GPS fix. :grin:
@Smojo
NLP is NOT supported, please read Faq - DivestOS Mobile
NLP does NOT speedup GPS TTFF.
Thx for pointing to it. Good and detailed FAQ I like that.
A detailed question:
GPS should lock within 2 minutes when outdoors and within 10 minutes indoors. Maximum GPS TTFF is 12.5 minutes due to their orbit and transmission rate.
Does this mean less than 2 minutes is not possible with DivestOS?
or are there any speed up possibilities to get (at least a rough) position in these points?:
  • On Tensor devices both PSDS and SUPL can be used to speedup GPS TTFF. It is recommended to disable SUPL on these devices.
  • On newer Qualcomm devices (ones that’d typically use xtra-daemon) SUPL is the only mechanism to obtain the almanac to speedup GPS TTFF. PSDS is not supported. It is not recommended to disable SUPL on these devices as it will cause very long lock times.
  • On older Qualcomm devices (ones that’d typically use libloc) PSDS may work in addition to SUPL to speedup GPS TTFF. It is recommended to disable SUPL on these devices.
In my case it is an FP3. It doesn’t have a Tensor chip. So I can strike out the first one. How do I know if the FP3 is in category old or new Qualcomm device (Snapdragon 632)? :thinking:
If 2min is the best case I have to leave the house 2 min earlier. ^^ quite challenging in a bigger city where life is busy and navigation is needed quite often. :relieved:
Of course it is possible to be quicker, initial lock can be as much lower like 10 seconds. Warm locks can be even quicker.
FP2 is in the old category. FP3 and FP4 are in the new category.
The full list is here: Network Connections - DivestOS Mobile
This is fundamentally how GPS works, the other devices just lie to you by sending your information off to a server to be processed and have that network location injected as GPS output.
Update DivestOS and keeping root worked without issues.
And you were right @anon43585658 restore images was not needed.
So the procedure is simply:
Installed GPSLogger | F-Droid - Free and Open Source Android App Repository and monitored this a bit.
Inside my house I don’t get a fix at all (waited longer than 15 min) even it shows 8-11 Satellites from time to time (had the phone near to a window), so a bit strange. Will test outsite when I have some time.
@Smojo
I recommend this app for testing: GPSTest | F-Droid - Free and Open Source Android App Repository
77 seconds TTFF when I checked it outdoor today. So less than 2 min :wink:
Indoor it basically stays like this forever (slighty changing the amount of Satellites):
Anyway I understand your argumentation why you don’t add NLP support or things like that, so I will live with that for the time I will go on using DivestOS.
Will you support the FP5 one day as well?
Your post was flagged, as your location is seen, therefore I will remove the screenshot
Oh ok, thx. What does it mean in detail?
How gets a post flagged? :thinking:
So the case the Screenshot was showing was the one were my location is not discovered, as I don’t get a GPS Fix indoor.
I dont know what @anon43585658 saw
There is a Flag next to the pencil you csn click on
January Update went well and without issues.
Same procedure as last time. :+1:t4:
Whenever I switch VoLTE on (4G Calling) I see every incoming call as ā€žUnknownā€ caller.
Anybody has such issue?
I’ve always had a question:
Why do smartphones slow down after updates, whereas Linux shows performance improvements with each new version :interrobang:
Debian 12 is indeed very good; there’s been a real improvement in performance. :+1:
@kujaw
related:
Thanks. I wish I remembered if I had it set on or off on my previous LOS system.
I can’t set Fdroid to automatically install updates. I have to install them manually. Is it correct behavior?
@kujaw
Please see Unattended updates for everyone, 1.19 is here | F-Droid - Free and Open Source Android App Repository
