Good morning!
I just had a problem using the forum on my FP. I started writing a post, and suddenly the post was posted without me wanting to (I was trying to type in a smilie: : - ( - maybe I hit enter, I am not sure). Then I wanted to edit the post to continue writing, but that was not possible, so I wanted to delete and start again.
Now the post is still there with a comment “will be removed in 24 hours blabla”. Why can’t it just be removed if you delete it like 1 minute after posting?
Then I wrote the post again and completed it, at the end of it (a sad battery issue) again I wanted to type the smilie : - ( - and this time the post disappeared completely! I could not find it any more. So I wanted to type it a third time, but then the reply-button did not react any more. I then tried to edit the 1st deleted post, but that was not possible either. I then got up and got my laptop and came to forum from it, and tadaaa! my 2nd attempt was still in the “reply window”, and then I posted it.
But I must say it was a bit unnerving trying to write from the FP and not really being able to.
So my questions would be:
do others have similar problems and what could I haven done differently?
why does a deleted post stay in the topic for 24 hours?
thank you!
this is the topic I meant:
https://forum.fairphone.com/t/battery-problems-wrong-charging-status-battery-might-be-dying/771/177?source_topic_id=10029
